Coolant expansion tank boiling over while bleeding
In the process of bleeding the system with the coolant expansion tank cap off and bleeder screw open the expansion tank started gargling and spewing coolant/water 50/50 all over the place.
This is a result of a nearly complete drain and refill while switching out the fan. I flushed the system using the shopvac method, so I would expect a ton of air and much bleeding needed.
Is this spewing normal? There were no cooling issues prior to today, just the fan not having a low speed.
Steffen.Johnson
42
01-25-2023 02:47 PM
