Exhaust Pop Between Shifts
Hello!
I found many online resources for this issue on other cars and know what the common resolution is, but I thought I'd check with some of you Mini gurus out there.
After changing the spark plugs and wires on the wifes '05 MCS, I notice a more pronounced pop between shifts and during higher RPM deceleration. Plugs are: NGK BKR7EQUP, and Wires are also NKG(the blue ones if it matters.)
I did a test and threw some Denso plugs in there, Mini specific, with the OEM wires just to see if there was a difference....it just ran like crap, with the pop. Test failed.
Now, based on this pop and a distinct smell of running a bit rich, I've determined the car is running a bit rich
1.) Is the pop as normal on a Mini as the interweb portrays?
2.) Is it common for these things to run a tad bit rich?
3.) If not, what commonly causes them to run a tad bit rich?
4.) Is my diagnostics even remotely close?
Thanks in advance!
Thanks in advance!
Thank you for clearing that up. As long as its normal. I never mind pops and gurgles of aftermarket exhausts, I'm a Subaru guy haha, but I thought it unusual for the stock exhaust.
07-16-2020 01:54 PM
