Replace Oil pan seal again?
06 r53
At my last service (90,00mi) they told me my oil pan seal is starting to seep and it will need replacing when it starts to leak. They just replaced it about 2 years ~60k mi (i used to trust them and I wasn't seeing any loss of oil or spots in the driveway when they replaced it last). Replacing the pan seal every couple years seems crazy.![Confused](https://www.northamericanmotoring.com/forums/images/smilies/confused.gif)
Is this a normal problem it seems like I've heard it is...
How difficult is it to replace at home?
Anybody ever look at the crank position sensor o-ring?
Often oil pan gaskets are replaced, cause the o-ring drips oil...looking like a failing oil pan gasket...
Some cars do have a few oil pan gaskets fail....but often I wonder about the cps o-ring....
Last edited by ZippyNH; 10-08-2013 at 02:18 PM. Reason: spelling...hate auto correct on my phone!!
Agree - I had oil all across the bottom of the engine and worried about pan gasket. Then saw the crank sensor posts and RTV'd that and everything is clean and dry now.
A shop I take my car has recommended twice in the last 20K miles that my oil pan gasket to be replaced. This is a huge job because the front of the car has to come off. I'm continuing to postpone - there is no oil on the driveway and no loss discernible on the dipstick which makes it a seep rather than a leak in my book, at least when the repair costs $800+. Whichever it is, I'd do both if/when you are in there. And have a look at the supercharger oil as well.
- Mark
- Mark
Oil pan gaskets do go...about as often as cps o-rings.....
One tip...dealers should have a 2 year warrenty on the gasket (if it was one)...
Etrain
14
08-20-2015 10:32 AM
Lex2008
08-16-2015 08:33 PM
minipopkart
08-13-2015 05:22 AM
