Recall Notice: Turbo Heat Shield (Oil Feed Line)
#51
Get one of these and your hood scoop will barely get warm.
before warranty expired at 50K. Don't think they help that much. I may try opening up the scoop so it actually breathes.
They just replaced my turbo and when they did they did the new heat shield recall. Maybe that will help keep it cool?
-Steve
#53
Had one of those installed after my chrome hood scoop started peeling around 25K. Just had the dealer replace the replacement hood scoop just
-Steve
-Steve
#54
Out of curiousity, has anyone heard of being reimbursed for a oil line replacement?
I had a 2008 MCS that I sold a couple months ago that I had to do this repair on as the lines were leaking oil and obviously wasn't covered by the Mini Next warranty. Getting anything back from the dealership would be awesome... as unlikely as that may be.
#55
#57
After fighting with Mini Canada I still haven't got much further.
They know its a service campaign and they are unwilling to do much for their customers about it. Talked to two dealerships, called customer support and still nothing. Apparently, if you post stuff on Twitter, they'll respond to you as well. Tried that and a Manager from Mini Canada called me just to tell me there's nothing that can be done until a recall has been created.
Coincidentally, when I had my car repaired last year, I notified Transportation Canada (Regulates automotive recalls in Canada) since it's very obviously a safety concern and design flaw. I manged to get the parts back from the dealership and sent it to them so they can use it in their investigation. I'm going to get in contact with the guy who I spoke to when I got it done and go from there.
Small claims? Possibly. I have a couple of friends who are lawyers so I'll see what they have to say about it. Some of the guys I know would do it for a case of beer, so it may be worth while.
#59
#60
Ok This morning and last two mornings I see a Green dense oil on my garage floor..
I went under this mini and I see on the passenger side under the air box oil lines leading to an electrical pump. Is this the Turbo coolant pump? Strange greenish dense oil something I have not seen before in any turbo car I have ever owned.
I hear a Buzz when I turn the mini off in that same area. but I don't an do not hear while running only when I turn it off. It like whines down. Power steering pump maybe? But power steering fluid is pink if I'm not mistaken. Correct me if I'm wrong. I have 77,000 miles so any help would be appreciated. PITA! one thing after another.
#61
The power steering on the R56+ MINI is a closed system. Do you have any pics of the fluid under the air box or the leak location ?
#63
The turbo aux water pump was recalled about 1 1/2 - 2 years ago. to the updated part 11537630368 , call MINI dealership and see if yours was done and updated.
, it sets up near the front of the transmission on the driver side and when working its makes a buzz noise after shut down and then shuts off after a minute or two. Does not run long all the time. When its does , there is most likely a coolant leak elsewhere.
11537630368
https://www.northamericanmotoring.co...ound-like.html
https://www.northamericanmotoring.co...8-no-heat.html
11537630368
#64
#65
Ha! too funny...yep not power steering can tell I'm old school...
But it is the aux pump failing..So here we go again replacing another recalled part that has failed within 35,000 miles..I called the local stealership this vehicle has had the procedure done on this particular part two yrs ago so I'm one yr past that mark 2012-2014..past warranty..two year warranty on parts recalled by USA Mini as per the young lady from USA Mini. Too funny she owns a Toyota..lol had too laugh...
It seems as though all the same parts on everyone's R56 are failing..Hmm!!
This shall be my last repair I'm off to Auto Buy and picking up a Kia 10yr 100,000 mile warranty...
Kimolaoha
07-05-2023 01:04 PM
Drivetrain removing heat shields for turbo cat ?
rckrzy1
08-11-2015 06:06 PM
