Clutch Creaking
Clutch Creaking
I've run across a few threads mentioning this problem or perhaps something similar, but none with a video, so I'm starting a new one.
Here's the sound I'm getting:
It disappears on mornings when it's been colder outside, but once the car has been running a while, it comes back. Generally, the hotter it is outside and the longer the car has been running, the worse the creak is. It also feels creaky, if that makes sense.
Transmission is a 6-speed getrag from an R53 with the Valeo single mass flywheel and clutch kit.
Any ideas on what it might be?
It sounds like it's coming from the engine bay, not the foot-well, but I haven't had a chance to crawl under the car yet to confirm.
Very interesting - thanks for the replies.
I've wondered before if it might one of those plastic bushings on the clutch lever shaft.
Number 5 and/or 6 in the diagram are the bushings. I'm pretty sure the bushings themselves can't be replaced without removing the transmission.
I might try spraying some white lithium grease or graphite lubricant on the outer bushing tomorrow morning and see if it helps.
When I replaced my clutch assembly I couldn't get the fork off the shaft so I unable to replace my outer plastic shaft bushing. There is a lock pin on the outside if it could be drilled or pressed out it would provide the access to replace the outer bushing by removing the outer clutch lever. Don't know if the pin can easily be removed
I don't think that the lock pin can or should be removed since it comes pressed in but I had the same issue with the fork, it would not come off, then when I finally decided not to change the bushings since I couldn't take the fork off one of them broke so I had no choice, so I hammered the crap out of the arm and ended up damaging the top of the arm but it came off, I did grid it back to shape put the new bushing back in and it works perfectly now, it's a shame that you have yo drop the tranny if that bushing breaks
drrigg
05-27-2022 03:31 AM
eliseo1981
11-02-2015 11:24 AM
unxpectederror
10-22-2015 12:16 PM
10-01-2015 12:13 PM
09-28-2015 09:13 AM
