R53 Xenon issue
R53 Xenon issue
For the past month my passenger side xenon (d2s) bulb would delay start. Just died the other day. So I did some research, checked my fuses and swapped bulbs still no luck. Next course of action was to swap the control module or ballast to see if the problem followed. Based on previous posts I was under the impression that its a simple plug and play between the two ballasts but after opening the covers they are wired differently did I just make that up or should I be able to swap them. Also when I removed the passenger side there was water in the cover were the wires plug into the ballast. There doesn't seem to be any visual damage to the electronics of the ballast. I understand these lights can be finicky, is it something I should just pony up the dough and have professional diagnose?
Any input as to where I should look to find the issue? Should I be able to simply swap the ballasts? Not too mechanically inclined so any advise is much appreciated.
KCCO
Lawless
KCCO
Lawless
silence2-38554
98
09-21-2016 02:52 PM
phrza81
10-10-2015 11:37 PM
