05 MCS won't shift while the brake pedal is depressed....
Hey guys, I've been trying to fix this on my own since August and have failed miserably so I'm hoping I can get a solution for my problem specifically. In August, As I was driving my wife to work, suddenly her mini would not go into gear. No matter what I tried I could not get it into a gear and was forced to pull it to the side of the road, while I continued to fail at getting it into any gear.
The clutch pedal also hit the floor and has absolutely no resistance now. I can pull it back to the top position and with a small push the clutch pedal hits the floor.
As of right now I have replaced the slave and master cylinder and power bled the system twice. Today I went back at it after fixing a leak from the new slave cylinder, and now I can get the car in to gear, but ONLY if I do not touch the brake pedal. The clutch pedal is still limp and I cannot for the life of me get any pressure in it. Once the car is in gear, if I hit the brakes, the car dies... I am completely lost and need to get this problem dealt with once and for all. Any and all help would be MUCH appreciated as I am my wife's transportation to and from work which has forced me to be unable to work until her car is back on the road. Thanks
Essentially you have to bleed the slave with the pedal compressed. There is a tool for that but you can also use a friend.
Rich
07-16-2020 12:54 PM
Powershift
08-16-2015 05:14 PM
Colt45Magnus
08-12-2015 06:43 AM
