Replace cat by itself??
I have code P1038, high voltage to the o2 sensor bank 1, sensor 2. And now I have code P0420, catalyst system efficiency below threshold bank 1
I'm leaning toward both these codes being cause by a bad o2 sensor, post catalytic converter. Ive had P0138 for months, I'm thinking that the computer is thinking the cat is dead because the readings between the two sensors haven't changed in quite some time.
Does that make sense to anyone else, or is my thinking illogical?
Car has 154,000 Kilometers on it. (so just under 100k miles)
My other questions is are you able to just cut out the cat and weld in an aftermarket catalytic converter made by Magnaflow or something, instead of having to buy the entire exhaust manifold / cat assembly. It seems like such a stupid design to have both those parts as one.
just figured i would toss it out there that i have for sale a stock exhaust manifold, cat, and already one-ball modded catback piping with stock tips off of my 03 s with about 60k miles on them. no problems. located in northeast CT if youre interested.
however, it sounds like your o2 sensor/s could be the issue. if you provide the year and model of your vehicle, as well as any modifications, we can help more. there are many threads on here related to problems with o2 sensors.
just know beforehand that if replacing the pre-cat/upstream sensor, you MUST get the NTK brand. the post-cat/downstream sensor can be replaced with Bosch.
if you decide to get a new cat as well, magnaflow does make a high flow model which i had installed on my car. to my knowledge, it can be used with the stock exhaust manifold and back piping. i have a header and aftermarket exhaust installed, so it was necessary for my needs, but its a quality high flow cat for the price in my opinion. ill look up the correct part #'s for each of those pieces for you, and youre interested in my stock exhaust parts, just send me a pm.
I have stock header/cat --> stock pipe size ---> back to what looks like an aftermarket or a replaced resonator ---> into two smaller sized magnaflow mufflers.
The resonator has a piece broken off inside and it rattles around. it is fairly new so I can only assume it is a cheaper aftermarket piece.
Magnaflow High Flow Cat
Part # 94136
NGK PRE-cat o2 sensor
Part # 25648
Bosch POST-cat o2 sensor
Part # 13878
(i like amazon. usually cheaper than most places and usually free shipping)
again, mine is an 03 s, but as far as i know, they are the same.
Part # 94136
Part # 25648
Part # 13878
I'm leaning toward the second O2 sensor being faulty, which is causing both codes.
Part # 94136
Amazon.com: Magnaflow 94136 Universal Catalytic Converter (Non CARB compliant): Automotive
Part # 25648
NGK 25648 Oxygen Sensor - NGK/NTK Packaging : Amazon.com : Automotive
Part # 13878
Amazon.com: Bosch 13878 Oxygen Sensor, OE Type Fitment: Automotive
Part # 94136
Part # 25648
Part # 13878
good stuff, thanks. I checked if "it fits" on the amazon site for the cat, and it says it doesn't. How do you know if that particular cat will work with our cars?
in my case, i had them weld a flange onto the header side, as to keep the header in tact, and then just weld the back side to the back piping.
also, i believe this cat has a 2.5" inlet and outlet, which is a little larger than our stock piping, but that is part of what gives it the high flow properties (aside from the internals of course).
if it doesnt seem right to you, i understand. doesnt hurt to keep browsing if your in the market. that is the exaxt one i have on my 03 s though.
The CEL just needs to be cleared, if you don't have the ability to clear it just go to Autozone or Discount auto parts they can clear the code for you for free. If the problem was your sensor the CEL wont reappear.
ok thanks, we dont have autozones here and i'll likely have to pay some shop to clear the code.. may as well have them replace the o2 sensor if thats the case
http://www.ebay.com/itm/New-Autel-MS309-OBD2-OBDII-Scanner-CAN-BUS-Car-Code-Reader-Data-Tester-Scan-Tool/121261175461?rt=nc&_trksid=p2047675.m1851&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D261%26meid%3D4374804048930918900%26pid%3D100005%26prg%3D1088%26rk%3D2%26rkt%3D5%26sd%3D191049833984%26
would this work?
would this work?
gmonde
09-08-2015 06:37 AM
08-12-2015 01:24 PM
Drivetrain removing heat shields for turbo cat ?
rckrzy1
08-11-2015 06:06 PM
iamcamkeenan
08-10-2015 03:31 PM
