Coolant hose rubbing IC plenum?
Just trying to help a buddy out with a chronic coolant loss issue. We were poking around putting a new belt on it the other day and started looking for this coolant leak. Car is an 04 with around 115k miles.
We came across the short upper coolant hose rubbing right against the plenum. It appeared to have worn/torn the hose enough to let it leak.
Surely its a motor mount issue, but is it a mixure of all of them or just the large upper one?
Also if anyone knows where to buy some of those IC cover bolts, feel free to speak up.
edit: ended up being a busted up core support, allowing radiator to flex.
What year car....
The mounts changed in 2005....
Switched the upper to an oil filled ball in a metal can.... With a bolt sticking out...
The rubber tears...a black too leaks out...engine moves...
With time the lower wears....then clutch issues can start...
There are a few diy's for changing the upper....pretty cheap part...usually less than $100 depending on the maker....can have a shop do it for about $200....but for about $20 in extra tools, most can diy it.....
Pre 2005 cars have a different mount....they still get sloppy....
car is an 04, has the huge metal can looking mount with the bolt on top.
It also has a really weird clutch noise at idle, sounds a bit like a diesel(only makes noise when foot isn't on clutch pedal @ idle). So its funny you mention clutch issues.
Newer style...http://www.waymotorworks.com/afterma...unt-04-06.html
and the older..
http://www.waymotorworks.com/oem-eng...4-r50-r53.html
OEM Upper Engine Mount for 02-03 MINI Cooper R50 and Cooper S R53. This is the mount that is on the passenger side strut tower and has the bar running down to the engine. The rubber in this mount is known for going bad. Also if you EVER have the passenger engine mount fail or wear out this mount ends up taking the extra force and breaks. So good rule is if you replace one replace them both otherwise the one you don't will cause your new mount to wear out or break prematurely.
Check yours for spliting today. Worn motor mounts will cause extra clutch wear and other mounts to wear.
http://www.waymotorworks.com/oem-min...t-r50-r53.html
http://www.waymotorworks.com/oem-upp...3-r50-r53.html
This is the OEM lower engine mount for your 02-06 R50,R53 MINI Cooper and MINI Cooper S and 05-08 R52 MINI Convertible. As these cars are getting older we find these mounts worn out or the rubber torn. So if you've had to replace your upper motor mount check this one. Because if your upper mount breaks the stress on this one can cause it to also break.
includes 1 lower mount
Definitely the newer mount up top. I'm going to have him order the upper and lower mounts to get the engine sitting right, so there will be little doubt as to if it will fix the angle of the engine in the bay.
I've already replaced the fuel filter, oil pan gasket, plugs, interior and engine air filter, leaky/torn cv boot. Learning my way around these cars slowly but surely. Still need to do the crank sensor o-ring though. Maybe one day this thing will be leak free.
Thanks for helping out!
I replaced the upper and lower mount, with very little to no change. The upper mount dribbled a little oil on me when i replaced it, but it wasn't too bad. We went ahead and put on a new coolant hose too, but i imagine it will have to be replaced again soon if i cant get this worked out soon.
Is there usually some sort of spacer between the frame and the radiator?
There should be a ring that holds the coolant hose away from the motor, it attaches to the center bolt hole on the intake manifold. I'm looking at your hose in the pic, it looks very low. The hose should run just below (About an inch below) the top of the front fairing/fan shield assembly. Pretty Much parallel to the top of the radiator.
You might want to grab the VIN and zip over to real OEM. They have a great image drill down and allows you to see how some things are assembled.
I didn't know your friends car's specifics, so these may be wrong. But take a look to see if you can find things that are missing like the clamps (#7?) mentioned above
http://realoem.com/bmw/showparts.do?...33&hg=17&fg=30
(I'm on he iPad, I can't copy the image in here directly)
Thanks guys, he purchased the car in a dire need situation and didn't really do much homework before he bought it. The car was involved in a wreck prior to his purchase so it is completely possible there is something missing. Luckily the car has been pretty faithful given how he drives it about a thousand miles a week for work, without cruise control ( ouch!).
Here is another pic I had him snap. With the obligate zip tie...
Thanks guys, he purchased the car in a dire need situation and didn't really do much homework before he bought it. The car was involved in a wreck prior to his purchase so it is completely possible there is something missing. Luckily the car has been pretty faithful given how he drives it about a thousand miles a week for work, without cruise control ( ouch!). ....
Something just looks...er...odd...about that frontend....maybe having stuff pushed an inch or so out of place, and having some parts used to fix it that ....er...almost fit....will work...
I would do the best you CAN with a zip tie etc, and hope for the best.
Since oil came out of the motor mount...fortunately that was needed...
I would offer onecbit of advise...
Remind your friend that his mini REQUIRES 90+ octane....going with less might save $2 on a fill up, but will cost him $2000+ when he starts to get misfires from a burnt valve and the head must come off for a head job.
Driven nicely, and given regular matainance, they can be reliable cars...
But abused or neglected.... They are money pits.
Folks sometimes get into near religious wars about how often and what to change their oil with...but forget to Change the coolant (due every 36-48 months) then wonder why they have a plugged heater core, oil cooler, and a failing head gasket.....
I have yet to put it into service mode, so i haven't been on the lookout for any major damage. I withheld the wreck part at first because i wanted to cover the usual suspects at first.
The condenser(in front of radiator) has a nice curve in it, so if it was the original one, the front crash bar would have indeed been pushed in 3-4 inches. If it isn't the original, its anybody's guess.
If the crash tubes are toast, are they replaceable or it is part of the unibody/frame?
Steffen.Johnson
42
01-25-2023 02:47 PM
GAT
10-04-2015 07:27 PM
