Obdii scanner not pulling codes
*OBDII not reading codes
Hi,
I have a 2008 cooper sidewalk edition convertible. I have the common problem of ABS lights and triangle with exclamation point. In the mornings when I start the car no lights show up the after 2 minutes of driving softly the brakes vibrates and make a grinding sound. Then the 2 lights come on and the car seems to run fine afterwards.
I bought an OBDII scanner and no codes woulds come up. I took it to my mechanic and he had a more professional scanner and he couldn't pull any codes either. He thought it may be the ABS pump or that the computer is bad.
What are your opinions please. how hard is it to change the computer and kind should i get, (i've seen aftermarket types)
Thanks!
Hi,
Thanks!
Hi,
Thanks!
Hi,
Thanks!
If your mechanic tells you this without seeing the codes, I'd find another shop or be very careful. It takes a proper OBDII reader to read anything else than Engine codes. Most scanners will have a generic option for other brands, like our Techstream at work (Toyota scanner), but won't let you see abs, trans, airbag, etc. I bought a Mac Tools Launch scanner that does pretty much every brands and modules. My airbag light was on and since I don't have a laptop, it was cheaper than getting a software AND a laptop. 300$, but I'm not limited to Minis, so it wasn't a bad deal.
As for your problem, it could simply be a faulty abs sensor, but the only way to be sure is to have the code and to test it.
sdotbailey
R55 :: Clubman Talk (2008+)
09-16-2015 09:03 AM
bcman
08-28-2015 04:47 PM
PSIChocolate
08-13-2015 12:46 PM
