Sudden Misfire
Sudden Misfire
Hey all, I have a perplexing issue and I am at a loss. I have a 2003 mini cooper R53 which is experiencing a sudden misfire on 3/random misfire. I picked up the car from my father who garaged it and didn't drive it all that much. It has 65k on the clock but for the last three weeks, it has been driving flawlessly. We changed the coolant, gear oil, air filter in the time he had it. I have put 2-3 tanks through the car myself.
I should start at the beginning to fill you all in. Friday I was driving to work (35 mi drive out of town) and I neglected to get gas thinking the small town I currently work in would have 91. They did not. I was in a pinch as I had to get home so I put in $20 worth of 87. I didn't think it would be an issue.
Fast forward to yesterday. I detailed the mini, drove it in the morning and when I tried to drive it later, it was missing terribly. It is no slight miss either, it will not idle without bucking and makes the car practically un-drivable. It should be noted that I there was ~1/4 tank of 87 left when it began missing. Today I pulled the plugs and indeed cylinder 3 was gassy. I regapped all the plugs, bought new spark plug wires, put in a full tank of premium with lucas fuel treatment to no avail. I also pulled the codes and got a p0300 Random/multiple misfire detected code.
Possibly unrelated, but worth a mention, the car has bubbled over the coolant overflow bottle in the recent past, but my father and I replaced the bottle as I thought it was cracked. I thought that this issue might be tied back to this as I have been unable to determine if the radiator fan is operating correctly. I have used torque on my android phone to monitor the coolant temp and it never goes over 205 F.
Any insight or experiences? I would like to rule things out before I go throwing parts at the car. The suddenness of onset of the misfire makes me think it's a fuel issue. Maybe running it low on fuel sucked up water/debris.
$20 worth of 87 octane.....in a nearly empty tank....ouch...
Hopefully it did not cause a burnt valve....
nuff said...but could have been a $1500 error....good luck...
Might be worth getting to a garage for a compression check...pretty easy...
Can be used to rule out or pinpoint the issue as mechanical....
Hopefully driving sensebly prevented any damage....but the fact the car started having a misfire issue RIGHT AFTER YOU USED 87 is telling.....
If the tank has been filled with high octane fuel...and still has a misfire within a few miles...kinda tells the story.
Be honest with the shop....tell them the same info.
Maybe it is a bad wire or coil...and the fill up was purely coincidental.....
I tend to look at the worst case....
Then figure out what simple cheap stuff can cause the same issue....and go from there...
A compression check is about the same labour as a sparkplug change...so minimal...and can be CHEAPER than throwing a bunch of parts at a car HOPEING it will fix it.
A coil at $75-150, wires at 50--75$, it adds up quick. Sometimes a pro is well worth the the $$.
I hope it is a coil/clogged injector/fuel filter/plug versus something major. There was no other option other than 87 and it was the only station. That and my state doesn't sell over 91 at the pump except for some racing fuel. I still cannot believe that 87 would so harmful in a pinch. Thanks for the input though. I'm going to pick up some dielectric grease and give that a go before dropping the car off tonight.
Don't panic. Putting some 87 in there while not optimum did not cause you to burn a valve. The engine has a knock sensor & will dial back ignition advance so it won't detonate. Burned valves are not caused by spark knock, holed & cracked pistons are.
You may want to do a compression test & a leak down test. This may be related to to the boiling over coolant issue. Head gasket, maybe.
Try swapping coil packs with a known good one. Don't buy an MSD or Screamin Demon.
The dealer diagnosing this problem may save you money. It costs a lot to keep throwing parts until one sticks.
R53 noninterference.... Thanks to the low compression pistons...
R50 interfearance.... Due to the higher compression pistons...(pretty sure on both).
Last edited by ZippyNH; 04-03-2014 at 06:55 PM. Reason: portions to pistons....hate auto-correct!!
Very glad it was a blown head gasket or other spendy fix.
wildwestrider
11
01-29-2016 05:06 PM
dutchhome
09-30-2015 07:17 AM
