SEL Fault Codes
SEL Fault Codes help!
My Service Engine Light is on. The code I got from the onboard computer using the built in test mode for the cooper are
step 14.1 - 20280
step 14.2 - 63280
step 14.3 - 64280
step 14.4 - 65280
I don't know which one is the true fault. I used the onboard test function. step 14 and did 14.1,14.2,14.3,14.4 and I got these numbers.
Can anyone give me some more info on these codes?
Thanks!
step 14.1 - 20280
step 14.2 - 63280
step 14.3 - 64280
step 14.4 - 65280
Thanks!
I haven't seen any reference to these codes posted anywhere. They're definitely not OBD-II DTCs though - one thought, if you don't have your own scan tool is to run over to the local Auto Zone or other chain auto parts store -- most of them have an OBD scanner that they can hook up and read the codes for you, at no charge.
If you do that, let us know what you find out.
Steffen.Johnson
71
01-26-2021 09:11 AM
ShadyCoop
09-20-2015 08:57 AM
sirfrank
09-11-2015 01:36 PM
