If its not one thing its another
Old 05-30-2014 | 05:58 PM
jamez's Avatar
jamez
Originally Posted by nlamunion
So the list of things wrong: harmonic balancer, belt, tension assembly, valve cover gasket, right inner boot, both front tires & air filter. So the 1st 4 things listed are big and def caused all the problems. For all $2200 but waiting on tires (gonna replace all 4) and can do the air filter myself. Any suggestions on tires?
Just glad that I didn't destroy my engine since I was out of oil due to the leak.
What leak? I don't see one listed. How much oil was left in there? Did they drain it? Are you saying the valve cover gasket leaked 4L of oil?
If the engine went into limp mode due to lack of oil, it's toast (ask me how I know). But if the harmonic balancer/tensioner caused the limp then you probably still have a decent engine. If you really cared to check up on the engine, you can have your oil tested by companies like Blackstone.
  #27
Old 05-30-2014 | 06:40 PM
nlamunion's Avatar
nlamunion
There was a leak, guess a decent one since I put around 4 bottles in around 2 months ago. For some reason my ******* self didn't think about a leak. The guy said I went into limb mode bc of the harmonic balancer. Now that I know to keep an eye on the oil I will doing that....... Never had to worry about it with the Toyota (although I got an oil change more frequently).
  #28
Old 05-30-2014 | 06:42 PM
nlamunion's Avatar
nlamunion
Are you saying I can have black stone check the oil to check to see if the engine is messed up?
  #29
Old 05-30-2014 | 07:13 PM
minsanity's Avatar
minsanity
They just analyze your oil. Did you go for the ATI? Coz if you went back stock, that will happen again. Have your mechanic check the ff:
-heat exchanger o-rings tend to leak w/ age
-crank seal while changing the damper
-crank position sensor
-oil filter housing, if leaking, gasket isn't pricey.
-oil pan gasket
  #30
Old 05-30-2014 | 07:20 PM
cerenkov's Avatar
cerenkov
I see that you're in the Raleigh area, what shop did you bring it to?
There is a good one about 1 mile north of downtown on Capital Blvd.
http://www.euromotorsnc.com
I've been there and many people on this forum have been happy with them too.
  #31
Old 05-30-2014 | 07:21 PM
jamez's Avatar
jamez
As already mentioned, Blackstone analyzes a sample of the oil. They can identify if there are traces of metal and what kind of metal (helps to tell what parts are failing). It helps to know if the engine is spitting out metal, that way you can figure out if it's been damaged by the consumption. I doubt it leaked. You would have noticed 4L of oil on the ground.
  #32
Old 05-30-2014 | 07:34 PM
nlamunion's Avatar
nlamunion
I took it to apex Peak auto, saw it suggested on tarheel mini. My car broke down about 5 miles from them so to have it towed to capital blvd would've cost way more than I had (insurance coverage).
I'm sure they are replacing with OEM parts, of course they started this am and are not open this wkend to find out for sure. After reading other forums I will be replacing stuff.
  #33
Old 05-30-2014 | 07:45 PM
nlamunion's Avatar
nlamunion
I live in an apt complex so when I leave a spot I never return to it available so if there was a leak I wouldn't see it. I will look into Blackstone
  #34
Old 05-30-2014 | 07:48 PM
minsanity's Avatar
minsanity
For your benefit, please heed & go ATI. OE might cost you the same or even more & worse, they'd fail again.
  #35
Old 05-30-2014 | 07:58 PM
nlamunion's Avatar
nlamunion
Looking it up now. Thanks for the info
  #36
Old 05-31-2014 | 04:23 PM
nlamunion's Avatar
nlamunion
Anyone have any opinions on Goodride tires? All 4 tires need replacing & my coworkers husband can get goodrides z rated for $400.
  #37
Old 05-31-2014 | 05:33 PM
bavmotors's Avatar
bavmotors
I feel your pain, my harmonic just crapped out, time for that and the pulley tensioner. I'm skipping the ati and going for the fluid filled pulley for $299.
  #38
Old 05-31-2014 | 07:43 PM
minsanity's Avatar
minsanity
Bav, I've seen both PRW & ATI. I chose the latter as it's just better made than the former from China. For the PRW, inspect the hole for burrs. If any, File & sand them down smooth before installing.
For tires? Here's a sampling:
You can get Chinese Goodrides for sub-$100/corner:
http://m.ebay.com/itm/205-45-17-205-...-/221183392273
While Federal 595s are better known & have better value:
http://m.ebay.com/itm?itemId=281231360288
An even better option: wheel & Bnew tire set:
https://www.northamericanmotoring.co...ion-tires.html
  #39
Old 05-31-2014 | 08:06 PM
bavmotors's Avatar
bavmotors
Hopefully my choice to save $50 doesn't cause any issues, I really wouldn't cheap out on tires, that almost always bites you later.
  #40
Old 05-31-2014 | 08:14 PM
minsanity's Avatar
minsanity
Not saying PRWs aren't any good. They're definitely a great upgrade to stock.
  #41
Old 05-31-2014 | 08:16 PM
minsanity's Avatar
minsanity
On the tires? I'd get the wheel/tire set. They're pre-balanced & ready to install, too.
  #42
Old 05-31-2014 | 08:26 PM
nlamunion's Avatar
nlamunion
Wheel/tire set? Not sure what that means...... New rims with tire?
  #43
Old 05-31-2014 | 08:31 PM
minsanity's Avatar
minsanity
New bridgestone pole positions on stock S-Lites
  #44
Old 06-01-2014 | 06:10 AM
JRhea's Avatar
JRhea
Tires????
I'm ready to purchase my 4th set of Sumitomo's HTR ZIII. 215-45-17. Most bang for the buck...fun,great looking, grip, great in rain,and 30k miles
And they're not made in China!
  #45
Old 06-01-2014 | 06:20 AM
nlamunion's Avatar
nlamunion
Great in the rain is def what I need...... I have done more sliding around in my mini than I did in my truck & not sure if it's the tires or what. I have nexum 5000 I think on my mini now. Never heard of that brand.
  #46
Old 06-01-2014 | 07:57 AM
Rich.Wolfson's Avatar
Rich.Wolfson
So I have an '05 R53......
I'm a little frustrated...
The limp most is most probably the Damper. ATI is the way to go and the job is easy if you have the correct puller. If you never changed your tensioner and belt, do that while you are there.
Limp mode can also come from a bad Bypass valve. A lot of people like the DT one but I didn’t like how it felt and went back to stock. But that would happen if you punch it and it goes into limp. If you’re just tooling around, the damper is most likely the problem.
///Rich
  #47
Old 06-01-2014 | 08:11 AM
nlamunion's Avatar
nlamunion
It was the harmonic balancer which I think is the same as damper. I'm having the shop I towed it to do all the work since I'm not very car savvy and don't have the time to mess around and learn this time around. I am going to start learning though some DIYs. Going to change to a cold air intake which I think will be easy to do. I live in an apt so only so much I can do there.
  #48
Old 06-01-2014 | 09:19 AM
JRhea's Avatar
JRhea
Originally Posted by minsanity
Whenever I buy used, I start fresh w/ new fluids. Oil, coolant, brake fluid, tranny & w/ the MINI, even fresh CHF11s Power Steering fluid. I never rely on service records. Use top tier petrol too. 93octane up.
Known weaknesses of R53 (most or all are DIYable):
-Crank Pulley. Change to ATI Super Damper.
-Belt tensioner. Swap every few years w/ $80 Gates from Amazon
-Lower Control Arm, swaybar bushes. Go Powerflex. When doing these w/ subframe off, do the ball joints, PS hose clamps & PS fluid change.
-install Cravenspeed or VIP strut tower reinforcement plates.
-low speed cooling fan. Do the resistor mod or bypass the low speed resistor. There's a sticky on this
-check potential leaks from the ff:
Thermostat
Crank position sensor o-ring behind the radiator
Oil pan gasket
Heat exchanger under the oil filter
Power steering cap O-ring & hose clamps
Coolant Expansion Tank splits. Swap w/ Canton or RMW w/ real caps
All these aren't really difficult to do. There are many threads that discuss these in-depth.
Minsanity....you nailed it with your list!!! Been there, done all of that. I would include the idler pulley in your PM list. Mine exploded at 65,000. I replaced it again at 165K as PM.
  #49
Old 06-01-2014 | 09:23 AM
JRhea's Avatar
JRhea
One last thing on the Sumitmo's.....they're very quiet. I had Kumo's on it at one time, great traction, but they made the car sound like I was driving a half-track on it's way to war.
Look them up on Tire Rack
  #50
Old 06-02-2014 | 12:01 AM
minsanity's Avatar
minsanity
You're right, I missed that. Thanks
