How to take off coolant water pipe
Hi
Just had the engine rebuild done, and discovered a small leak on the water pump to thermostat coolant pipe
question is how do i take the pipe off to inspect/replace??tried pulling very hard but did not work
the part is this http://mini.sewellparts.com/oem-cata...SLCI-2012.html
Hi
There is a clip on the back end of the pipe on the thermostat end. Unclip it, remove the thermostat (requires removal of a bunch of coolant hoses as well as freeing one end of the plastic pipe), then pull out the pipe off the water pump. It's wedged in there tight, but will come out. Replace the gaskets before reinstalling.
Clearance are tight with the engine in place, but once the thermostat comes out you should also replace it as a preventative measure. Hopefully it leaked on the thermostat end, so you can leave the water pump side alone.
a
sempaipaul
10-26-2015 05:56 PM
