Electrical voodoo
Old 06-06-2014 | 02:14 PM
RHcoopers's Avatar
RHcoopers
Electrical voodoo
There a correlation with having the following?
- door lock actuators dead(both with FOB and toggle)
- rough starts, couple turns to get started
- 1 window slower than other, other window was working intermittently.
- AC compressor/clutch not turning on
Old 06-06-2014 | 03:38 PM
Fly'n Brick's Avatar
Fly'n Brick
Battery!
AutoZone or their competitors can have you in and out of the door in minutes.
Old 06-07-2014 | 08:03 PM
Capt_bj's Avatar
Capt_bj
old car . . .
Old 06-07-2014 | 08:33 PM
RHcoopers's Avatar
RHcoopers
Originally Posted by Capt_bj
old car . . .
Truth.... 2003 with 105k
Old 06-07-2014 | 09:00 PM
bmwr606's Avatar
bmwr606
corrosion at the main ground under the bonnet?
Old 06-08-2014 | 02:00 AM
minsanity's Avatar
minsanity
Possible answers:
- door lock actuators dead(both with FOB and toggle):
http://m.instructables.com/id/Repair...or-L/?ALLSTEPS
OR new 1s!
- rough starts, couple turns to get started: check fuel distribution, vacuum lines, purge valve & ignition systems
- 1 window slower than other, other window was working intermittently. Check motor & linkages.
- AC compressor/clutch not turning on:
http://m.ebay.com/itm/221330298065?nav=VI
Old 06-08-2014 | 07:14 AM
Fly'n Brick
+1 on all that but still, don't overlook the battery and/or charging system. A weak, dying battery drives the ECU absolutely crazy and all sorts of weird electrical shenanigans appear.
Old 06-11-2014 | 11:34 AM
RHcoopers's Avatar
RHcoopers
Battery and alternator are super healthy. Time to start checking the failing equipment... Love old bmw issues.
Old 06-11-2014 | 04:29 PM
Fly'n Brick
Good luck with finding that ornery gremlin. Nothing lasts for ever except nothing.
Old 06-13-2014 | 11:45 AM
RHcoopers's Avatar
RHcoopers
Originally Posted by minsanity
Possible answers:
OR new 1s!
A C Clutch Coil Fits 2002 2003 2004 2005 2006 2007 Mini Cooper | eBay
Thanks for this post, man! I'm going to take a chance on the coil just because I'm on a budget. Do you have a link that shows just replacing that or should I refer to AC compressor replacements? I want to avoid service mode but if I don't have a choice then so be it.
USNAE2
16
06-17-2022 08:17 AM
ryGuyMCS
10-06-2015 01:04 PM
Levers_and_Gears
09-28-2015 05:42 PM
FatherG
09-27-2015 06:12 AM
asmasm
09-21-2015 09:23 AM
