Another Power Steering Thread (alternator?)
Was listening to music for 20 minutes with the car turned off and started it up to drive home. The battery light stayed on when it started and i have no power steering. I did some searching and it seems the factory alternator is a piece of junk. Does anyone have a procedure for diagnosing this? I know replacing the alternator is going to be a nightmare as the front end of the car needs to come apart so i wanted to see if there are common issues that cause this that i may be overlooking?
Do you have a scangauge? You'll know if your alternator is charging or not. Or have your battery tested. If still good but just low on juice, chances are it's the alternator. Check all fuses 1st. The Denso unit isn't junk. Same core is being used on Toyotas & other *** imports & is known to run forever in those. In fact, you can get that same core/amp rating from not just salvaged MINIs but those Toyotas, too, & swap it into your shell if you're handy. Change the bearings while doing this. The MINI's cramped engine bay=higher temps + parasitic electrical loads beyond those in imports may be factors for its shortened life.
The"S" DENSO alternator is actually pretty good....far better than the valeo unit on the r50....
You can put a mini into "service mode" to get at the alternator in about 30 minutes...so no...no nightmare.... Look up "girls guide to service mode" for a good diy...
And just for info...the alternator on the S (DENSO) IS THE SAME core/windings used in most Toyoda's... Like my wife 's highlander... Going on 215,000 miles, still on the factory one...but rpms are hard on bearings and brushes...and that rarely goes over 3500 rpm..so that might account for the life differences....
A $10 voltmeter is the most useful tool to troubleshoot an electrical system.... I'd bet $$ it is an alternator issue...but check the voltages, ground wires, etc...the PS pump is MADE to shutoff if the alternator stops making current....
Etrain
16
08-05-2024 04:37 AM
Manny_cooper
09-10-2015 11:09 AM
minipopkart
08-13-2015 05:22 AM
