leaking turbo oil line
Old 04-23-2017, 05:35 PM
DneprDave's Avatar
DneprDave
DneprDave is offline
Rear main seal.
  #52
Old 04-24-2017, 05:31 AM
ECSTuning is online now
Received 2,092 Likes on 1,866 Posts
If it's just the bell housing and nothing else. It might be the main seal or the transmission fluid from the seal behind the guide sleeve.
Rear main seal:
https://www.northamericanmotoring.co...an-gasket.html
  #53
Old 04-25-2017, 01:00 PM
Detroit Tuned's Avatar
Detroit Tuned
Detroit Tuned is offline
Vendor - 15 Years
Originally Posted by BeardedForever
So what happened with this leak? I too have the same problem. I've previously replaced my oil feed line with a Detroit tuned line. I don't see where the leak could be coming from except inside the bell housing.
That leak would be rear main or trans input shaft, but a leak that small...i would wait till it gets a lot bigger or when you replace the clutch. It's super small.
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Kimolaoha
07-05-2023 01:04 PM
danielbrookes_9
10-03-2015 12:51 PM
patrioticmini
08-20-2015 10:54 AM
Laura Redd Casler
08-15-2015 09:32 PM
PelicanParts.com
08-14-2015 11:07 AM
Quick Reply: leaking turbo oil line
