R53 supercharger rubber boot failure
The rubber boot on my supercharger failed for the second time in 16 months. Both times were on the race track and the car went into limp mode. The first time I figured it mainly due to the car being 7 years old and rubber parts can dry out. But failing again after 16 months seems unusual?
I did a web search to see if this was common and I did not find anything. Has anyone else run into this and, if so, is there a better solution than OEM parts?
Deven
Deven
I read online that there is a 2 year warranty on the boot, so I will check with my dealer to see if this is covered on Monday.
Deven
If you search for intercooler boot on NAM you'll find lots of talk about them.
They don't fail often, but they are hard to seat properly and lead to issues if leaking.
As mentioned, aftermarket silicone ones are available, and are a PIA to put on. You can search for installation tips for the silicone boots, some have found that soaking them in boiling water before installation helps to stretch them.
Good luck.
Good luck.
After a little searching I think I'll go with these unless anyone recommends otherwise.
http://altaperformance.com/i-1400712...ed-engine.html
After a little searching I think I'll go with these unless anyone recommends otherwise. http://altaperformance.com/i-1400712...ed-engine.html
Go OEM IMO...
If the OEM ones are installed too tight, they can get cut by the bands....
About s year ago the part numbers on the bands changed....$$ went up...think the design is slightly different...
Most folks that go with the Alta's say "never again".... Getting them warm on hot water is said to make them more pliable.... But still a #$%& pain....
Go OEM IMO...
07-16-2020 12:54 PM
silence2-38554
11-12-2015 09:39 AM
