My squirters aint squirting.........
#27
Thanks, you are before the 1/2004 change up on the rear exhaust clamps. These tend to clang when rusted or falling apart. On the Center exhausts is usually the center bushings.
http://www.ecstuning.com/Mini-2004-Cooper-R53-S-Coupe-L4_1.6L_W11B16A/Exhaust/OE/
Center bushing, there are two. They can sag and then the exhaust can rattle.
On the rear hangers check the upper portions, that where they rust on boh sides ( Unless the car has the one ball mod) which the exhuast barrel on one side has been removed. You will need the clamps " For vehicles with production to 1/2004 " There is a left and right side upper and lower clamp.
Check the rear bushings also ( orange red color ) .
I would also check the exhaust heat insulation ( tin metal tunnel) is in place and is not vibrating under exhaust revs.
Thanks.
Thanks.
#28
#29
Might be the shield cover out side of the muffler housing rusting apart on the inside. Check the muffler barrel on top and for rattles. Rattles under certain revs.
#30
#33
One tip...
The outer part of the muffler/resistor has a mild steel heatshield....it rusts, and looks bad, but the stock system is stainless steel...
My outer heatshields on the "cans or *****" aka, muffler and resonator were rattling and full of holes...peeled it off...now quiet. The stainless underneath was still shiny and airtight....
Look around...feel for blowby...
#36
That does not look like the stock Cooper S muffler. Looks like and aftermarket one? And sounds like it separated inside.
#37
Drivetrain DIY-SC AIR DIVERTER / H20 SPRAYER !!!!!
Eurothrasher
09-02-2008 11:04 AM
W3IWI
02-18-2004 04:52 PM
