Timing chain tensioner came apart
#26
Don't go used with direct injection it would only be a core hopefully good for rebuilding. rebuilt from mini sites $3500-$4000. for any serious work take the front off, radiator and bumper, ac will have to be disconnected, not bad work and leaves you with great access to get to it all. if you have the ability least costly route would be clean up head, and re-ring and don't take out the crankshaft. time wise the swap can be done in a few days. If having the head planed mark the section that overhangs the block max 18thou. oh for the pull leave it all together even the harness stays on.
#28
I just experienced this exact situation yesterday while replacing my Sons tensioner on his 2010 Mini Cooper. I immediately started searching the internet for anyone else having the same issue. Both my wife an I have a Mini Cooper S and Mini Cooper S Clubman, which I've replaced tensioners on before, with no complications. This one worried me a bit. I spent a few minutes retrieving the plunger end, because I didn't have a magnet readily available. I was able to use a small probe to pull it to the opening where I was able to grab it. I'm going to take the part to our local Mini dealership and see what your technicians think of it. Fortunately, what tension was left, kept the part over the spring the whole time.
#31
Tensioner felt apart
Among other issues that I am in the process of fixing on my 2010 Cooper S I decided to remove the tensioner to take a look at it due to having heard the rattling noises that are associated with them. My intention was to replace it even if it looked OK. Anyhow, imagine my surprise when in the process of unscrewing it I noticed that the plunger end was not coming out. I removed the bolt portion and the spring came with it then I used my magnet to retrieve the plunger. Has anyone else had this happen, from all the pictures that I have seen of tensioners they are all one piece.
09R56
11-16-2022 10:49 AM
alistaircookie
10-08-2015 10:52 AM
iamcamkeenan
08-10-2015 03:31 PM
