Coolant coming from reservoir
Hi all!
New the forum, thanks for having me.
Here is what I've got going on:
About a year ago I had all the cooling hoses, water pump and thermostat replaced on my 03 Mini Cooper S because it was leaking coolant from the water pump. Everything has been fine until I was sitting in the driveway listening to the radio with the engine running for about 5 mins before I went into the house. I got out and the fan kept running for a solid minute. I looked underneath and there was a small puddle of coolant. It was obviously coming from the reservoir itself (couldn't tell if it was boiling over or leaking from the seams of the tank) It was a fairly cool day and the temp gauge never moved past normal. I've been checking the coolant daily since then and it seems to be dropping a little bit every day but the temp gauge never goes above half way. I've also checked the oil and it's nice and clean at a normal level.
Any suggestions on what it could be?
Kimolaoha
07-05-2023 01:04 PM
blackie
01-18-2017 09:56 PM
