Noisy clicking after parking
Old 07-10-2004 | 09:39 PM
Storm180's Avatar
Storm180
Hi all,
I've got a new MCS (no mods) with about 3k miles on it. Lately it is beginning to make a clicking/tapping noise from underneath the car coming from slightly behind the right front wheel and towards the centre after I park. It sounds like a problem with the heat shield, but I was wondering if anyone had some similar experiences or comments.
It would make sense if it was the heat shield, because I think every car I've owned has had those issues at one point or another. Charlie is just making himself at home. :smile:
Old 07-11-2004 | 07:16 AM
jerij's Avatar
jerij
Mine does it after 16k. Most likely heat/contraction/metal expansion/etc.
It hasn't detonated....yet.
jerij
Old 07-11-2004 | 08:05 AM
kenchan's Avatar
kenchan
Mine use to tap a lot when new too....noticed it even while at a stop light.
So did my other cars, so did not think too much of it. My MCS has about 12k miles and healthy. :smile:
Old 07-12-2004 | 10:37 AM
mattcoon's Avatar
mattcoon
I've noticed this, too. I have an 04 MCS with 7200 on it. It clicks from the passenger side at a stop and after I've parked. I assume it's just a heat shield expanding/contracting and not really any issue.
Old 07-12-2004 | 10:40 AM
Panganiban's Avatar
Panganiban
Same here. Right after I've parked it.
Old 07-12-2004 | 10:45 AM
MGCMAN's Avatar
MGCMAN
Sounds like hot metal cooling down. Maybe heatshield, maybe exhaust, maybe brake components. They all do it.
Old 07-12-2004 | 06:28 PM
pocketrocketowner's Avatar
pocketrocketowner
It is the black rubber thingys having at it, procreating......out to conquer the world.....
Old 07-12-2004 | 07:21 PM
SpiderKnight's Avatar
SpiderKnight
Mine did this as well. It also did it at stop lights.
Old 07-15-2004 | 08:34 PM
BradB's Avatar
BradB
It's the alignment of the heat shields on it's mounting bolts under the muffler and exhaust pipes. It is easily fixable under warranty. Just take it in. I did and it's quiet now!
Old 07-15-2004 | 08:38 PM
gomezmgg's Avatar
gomezmgg
It may be all the stainless steel used in the exhaust system and the heat shields under the car. SS has a high coff. of expansion and "grows" as it heats up then makes a racket as it shrinks back down. BTW if you haven't put you MINI on a lift and walked under it yet they're pretty cool on the underside too!!...........mgg
minimofo
11-16-2016 06:56 AM
08-25-2015 08:11 AM
08-19-2015 01:51 PM
08-12-2015 02:24 PM
08-07-2015 09:02 AM
