OBD no communication
So I'm still having a problem with the OBD connector on my R53.
Symptoms follow:
1:PCM light does self-check on startup (turns off, turns back off a couple seconds later)
2: Engine runs perfect, no issues driving.
3: Several different scanners have been hooked to the OBD port. All power up, but none are receiving info from the PCM
I have to figure this out, because the area I live in performs emissions inspections, and they need to talk with the computer to make sure everything is good to go.
I have talked to two separate MINI Service Writers, and they both stated that it would be a "straight time" repair to track down and fix the problem- That can get expensive VERY QUICKLY.
Has anybody else run into this issue? If so, what was the fix!!!
Symptoms follow:
R50/53 Help please.. Odd issue.
PsychoRallye
21
02-17-2019 06:08 AM
