2004 R50 Right side brake light not working
Hello,
I am having an issue with the right side brake light.
The following IS working fine:
Both rear lights
Both rear turn signals
Left brake lights
I have checked and replaced the bulb and that did not work.
If I connect the entire left lighting assembly to the right wire harness the bulb does not work.
If I connect the entire right lighting assembly to the left wire harness the bulb works.
I checked the fuses inside the car and they look fine.
Any suggestions would be greatly appreciated.
Thanks!
Garry
Both rear lights
Left brake lights
Thanks!
Garry
07-16-2020 12:54 PM
cm.d
08-19-2015 08:51 AM
