Checking for Boost Leak
Is there a process on the N14 engine to see if you are losing boost to a possible leak? I though there was something about it but I can't seem to find the info on the process. Something like a PVC port you put on the turbo inlet to check? While my nGauge (OBD based) reads I am generating boost (20 psi or so on DNA stage 3) I don't feel like that is actually what I am getting. There is a slight high-piched whine/air hiss that I hear under acceleration (not the typical CAI draw) and I would like to see if I can pinpoint if there is a leak by doing a boost check.
Any ideas?
-Z
Any ideas?
-Z
These cars are very temperamental if there is a boost/vacuum leak, but I would say start with checking all the connections of the charge piping for oily buildup, and if that checks out to move onto using a smoke machine to check for air leaks.
I've caught myself thinking there is an issue with my cars, when in reality there is nothing wrong, but being preventive is prosperous in the long run.
silence2-38554
98
09-21-2016 02:52 PM
Etrain
11
08-20-2015 10:22 AM
Indimanic
08-19-2015 11:08 AM
