Leaking upper molding of Hatch
So I have water coming in from between the glass and the inside the molding where the clips holes are located. Where would the source be and does anyone else have this issue with 1st gen hardtops? It drips on to my trunk floor. So aggravating! Body shop told me the glass has to be removed. I'll post a photo when I have the car back.
+1 check the gasket on the rear center brake light. Then check the drain tubes ( disconnected or clogged) on the rear if you have the sunroof.
![](https://www.northamericanmotoring.com/forums/signaturepics/sigpic130940_6.gif)
+1 on checking those rear drain tubes.
patsum
26
05-29-2021 06:29 PM
David Eric Rosenberg
R57 :: Cabrio Talk (2009+)
09-10-2015 12:34 PM
09-02-2015 09:05 AM
