Radio was Intermittent when turning volume knob
Radio was Intermittent when turning volume ****
My radio has finally stopped working entirely. Initially it would cut out (very abruptly) on its own or as volume control was turned. Then I could get it to come back on by rotating the volume **** quickly right and left; the sound would come back abruptly. Now it has stopped entirely. Has anyone had this problem? Hard to find the right words for the "search forum" function.
My mini is a 2004 and the radio is the Harmon Kardon. Nice radio until now!
Thanks in advance,
Kim
Thanks in advance,
Kim
Grab some electronics contact cleaner spray from the auto parts store. In the past I have had home stereo systems do the same thing. Spray the contact cleaner in and around the volume ****. It helped mine. If I remember correctly I used the a cleaner that was made for one of the air sensors.
On gen 1 MINI.
Yea, sounds like the contacts in the **** function, you will have to pull the deck head out and then remove the front panel or top panel to access the volume contacts.
I don't think it will reach it just pulling the ****. Worth a shot first i guess. I used di-electrical cleaner in the past for other electrical connections.
***** listed below. You will have to pinch and give it a good tug.
https://www.northamericanmotoring.co...io-button.html
On the Gen 2 , the **** is in the middle and pulling the center console unit is a bit more work.
I would try to just hit it first on that one once you pop out the ****, same thing , pinch and pull. Its the one at the bottom below the CD .
http://www.ecstuning.com/Search/SiteSearch/65123448285/
07-16-2020 12:54 PM
truedrew
R60/R61 Stock Problems/Issues
08-10-2015 10:39 AM
