Pros and cons of an automatic transmission in a Mini
#26
While this is certainly better than doing nothing, do note that drain/filling will usually only get about 2.5 (of 6) quarts out. If doing nothing gets you to 80k, will changing only a third of the fluid past the 'halfway' point be enough? Will you be replacing with full synthetic?
#27
However, doing nothing also ensures its own problems, so, since I can drain and refill the trans myself with no special equipment needed, it's an easy enough way to help extend the life of the AW trans in my Clubman.
2nd- Change to Synthetic. NO. I have been in contact with ZF and other trans reps over the years. They are generally in total agreement that you stick with whatever fluid the clutch/friction disc first absorbed when filled at build time.
So, since the AW fluid appears to be conventional ATF, I will stick with it and change it more often than I would have considered with Syn. ATF.
3rd- Zero plans to track or Autocross my S, if I did, then I would be changing the fluid far more often.
4th, off topic by way of apples to apples Vehicles, I drained and added 2 qts from my previous 1992 Montero every 6-8 months for 13 years. It was still going strong at 260,xxx miles when I got rid of it, and I bought it used with 152,xxx on it . Simpler auto trans from B-W I think, but I only used the Diamond SP-3 ATF fluid from the factory to keep it shifting right all those years.
It was always the guys who changed out to non- factory fluid who blew or lost clutch packs since they were SURE that synthetic fluid would work better for them.
#28
I am fully aware that a drain and refill does not get much fluid out. So much fluid is in the Torque Converter that you would need to either do a true flush via a filling machine as a complete service, or perform the simple pan drain and refill multiple times to ensure a complete exchange.
#29
https://www.northamericanmotoring.co...ml#post3828197
#30
Were these vehicles used as daily drivers or subjected to more extreme conditons? I found a post from another member that changed their ATF at 17k with synthetic and ran it till 70k with no problems. I know this is just one example but it's a success story.
Back to MINI's. If I had a long term test mule to try out various aftermarket ATF fluids, and money to fix anything that might go wrong from a different fluid being in the transmission, I'd risk it. But I don't. Just have my daily driver, and will keep that portion of it stock.
#34
An auto can probably get close to its published time most of the time.
#35
#36
Convertible 8.7 vs 10.0
Coupe 8.3 vs 9.5
Roadster 8.7 vs 10.0
Countryman 9.8 vs 10.9
#37
#39
Agreed but for the S it's 6.7/6.9 according to a UK magazine and I reckon you could easily lose 0.2 secs on a not quite perfect gear change.
09R56
11-16-2022 10:49 AM
lalroma
20
04-02-2022 06:19 PM
07-16-2020 12:54 PM
