'06 MCSa transmission woes
#26
I'm at 21k now so I'll post if mine fails in the next 10k. (Knock on wood)
#27
I don't know the % failure. I just know from reading trade articles and seeing giant threads on here and the VW site.
A normal service interval for tranny fluid is 60k miles or 96K KM for just about every vehicle except BMW and their "lifetime" BS. However, changing very often for this unit is likely a good idea. Go ahead and do it every 30k miles, as long as you do the procedure properly it can't hurt. 10k miles seems excessive and wasteful.
The main problem is in the VB design. It wears prematurely and the solenoids are pretty crappy too. Frequent fluid changes may postpone the inevitable.
#29
Maybe not. Changing very old fluid may cause gunk to break loose and clog passages. Some tranny folks don't recommend it. You are living on borrowed time though. If it were me, i'd sell it. As a matter of fact, I will likely sell mine this summer because I have the auto trans and I would rather this be somebody else's problem.
#30
As I detailed in post #18 of this thread, the tranny lives a hard life. It's tiny, undercooled and has to put up with 200+hp/tq.
I'm interested in seeing how the 9-speed unit, that mini will hopefully get in the next year or two, holds up compared to this one long term since it packs 3 more speeds in the same space--something's gotta give.
I'm going to change my 2.5 qts of fluid every 10k. It's not expensive or difficult and hopefully I can get to 126k someday with no issues.
#31
#33
There are dozens of people on here with dead auto transmissions on R53s, and I have seen people advertising dead cars on autotrader and kijiji. There is a trade mag that ran articles on multiple problems with the 09G trans. There are at least 3 rebuilding places that do VB rebuilds and keep these ones in stock. It costs a fortune to replace a bad tranny with about 12 hours labour, much more than an R53 is worth, like paying for the car twice. Once it goes your car is essentially worthless.
The choice is to sell and get value now or drive it until it dies. Neither is a good or bad choice it depends on your preferences.
With 126k miles, your car is not worth much so might as well drive it if you like it.
#34
#36
Ok in your opinion what is well maintained? It has lasted 126k with no problems and most that have problems seem to have them around the 80-100k time frame. I am thinking I should flush and change the fluid soon?
#37
on
From what other members have said our transmissions should be serviced every 30,000 miles or so. I know of a few that drain and fill every 10,000 and some that never have. In your case some would say change it, while others would argue against it. I would do a fluid and filter change if I was you.
#38
#44
#47
For people reading this thread keep in mind how many people are posting that their transmissions have failed. There are a few guys on here on here who have recently rebuild their engines with bigger turbos and forged internals running big power and torque as well as those with remaps that have had zero problems myself included.
My advise is be proactive and replace the atf at regular intervals.
#48
BTW with all of your mods etc, what milage is on your still good tranny?
#50
Also holding torque is not the issue, the problem is bad/soft valvebody and spinning sleeves. These are more related to wear due to number of shifts and maybe dirty fluid. Agreed clean fluid should prolong the life.
