Need a/c advice - compressor relief valve?
Last year while trying to improve the anemic air conditioning in my 2004 R53 with 120K I tried one of those DIY refrigerant-in-a-cans. While following the directions, and monitoring the pressure on the can's gauge, there was a sudden 'pffft' from the vicinity of the compressor. It sounded as if some pressure relief valve had been actuated. Thereafter the system lacked any cooling whatsoever, although the compressor still engaged and ran normally, which says to me that there remains enough refrigerant in the system to satisfy the low-pressure sensor and that the clutch is not bad. I took it to the dealer and they told me nothing other than the compressor is bad, and would cost $1,500 to replace.
Before I do anything to get this working again, is anyone aware of any such relief valve on the compressor, and if so is it a repairable part?
TIA.
TIA.
patsum
26
05-29-2021 06:29 PM
doug5g
09-02-2015 04:53 PM
