Stalling/engine dying on MCSa
on
A month ago my 2005 S auto had the engine stumble at a red light and the ecs and eml lights came on. The car recovered and the warning lights went off. It lasted for a couple miles then stumbled really bad while driving and the previous lights came on plus the engine temp, battery, and DSC and the engine cut out. I pulled to the side of the freeway and after a while started it back up to get it off the freeway and to a parking lot where it died again, and wouldn't start anymore and wouldn't start a few days later at the dealer. They replaced the crank pulley, oil pan gasket, power steering hoses, and timing case gasket. When I got it back it was consuming some coolant, but held consistent the last week and a half. Besides that it was running ok until yesterday. I went for a short drive and when I got back it was idling waiting for the garage door to open and the engine cut out. Engine and oil had gotten to operating temperature. Think the battery and temp light came on. It restarted right up to get it in the garage. Coolant looks ok in the tank. With the car off there is half a hole showing on the belt tensioner. The belt had been replaced about 6 months before this happened. I've got a 17% pulley. Any thoughts?
Your dealer replaced 4 things that have zero to do with a stalling car. It's not the tensioner either. There is big thread on this issue, unfortunately I don't think anyone has pinpointed the cause. My car did it a couple times where it started then died or started and ran rough. Been flawless for last 6 months. Could be an electrical issue, ECU fault, dirt in the fuel system???
on
patsum
26
05-29-2021 06:29 PM
R50/53 Help please.. Odd issue.
PsychoRallye
21
02-17-2019 06:08 AM
wildwestrider
11
01-29-2016 05:06 PM
