2012 standard mini Inlet cam sensor failed X2
I have a Standard 2012 mini and a reader and I have been working on cars etc for 40 yrs.
My question is, what should I be reading (volts) on the 3 wires feeding the inlet camshaft sensor? Can anyone tell me what they have with the car running or where I can get that info?
I get a check eng. light, reader says,
2968 Inlet camshaft sensor.
I replace sensor and clear codes... Car runs for a few days, eng check comes on, reader says,
2982 Inlet camshaft sensor
2986 Oxy sensor before cat bank1: syst check
2968 inlet camshaft sensor
I clear codes and run for a day
2968 inlet camshaft sensor.
Before I replaced the first inlet sensor, I checked it for continuity, it had none so I replaced. I checked the new one, it had 15.6 or so between 2 of the terminals. Now I pulled the new one and it has no continuity? I may have just burnt my way thru 2 sensors if I have a bad feed wire?
My question is, what should I be reading (volts) on the 3 wires feeding the inlet sensor? Can anyone tell me what they have with the car running or where I can get that info?
Thanks in advance,
Jeff
Thanks in advance,
Jeff
07-16-2020 12:54 PM
