head gasket install
ok, i think i answered this one on my own... no... if im wrong correct me quickly because im about to put the head on...
http://www.diynet.com/diy/en_engine_...276387,00.html
Most composite (as opposed to steel shim) gaskets require no additional sealers during installation. In fact, you risk premature gasket failure if you do use sealer or other type of coating on a composite gasket. The gaskets used on a bi-metal (aluminum head to cast iron block) engines have to accomodate the differences in thermal expansion between the materials. This is usually done with a teflon coating which allows the slightest amount of 'slip' between the head and block surfaces without actually breaking any seal. A gasket sealer applied to a gasket in this situation will prevent the slip from happening, and cause the gasket to be literally torn apart over time, causing a leak.
Make sure both surfaces are absolutely clean, and follow the torquing specs and sequence to the letter.
eatsleepautox
10-30-2015 06:46 AM
