knock noise after brake pad install
Hi, I opened a thread hoping I can get a response regarding this issue. I'm sure someone has ran into this before.
After replacing the front pads, with new oem ones I picked up from the dealer near me. I started to notice weird knock when I reverse the car and apply my foot on the brake for first time, after driving forward. If I apply my foot on the brakes again, I don't hear it.
If I drive forward for a while, then try to reverse and apply my brake again, I hear it...I checked all the bolts and everything is torqued to spec. rotors are still the original ones have about ~50-60% if that helps.
I appreciate all advice.
That's what I suspected first when I first heard it. I already went a second and checked the bolts. All bolts were tightened again, and still hear it. can it be the rotors? I also did notice the passenger side end link pushing that connects to the strut the rubber is cracked and leaked some grease out, was wondering if this is also a source of what may be the issue?
I just wondered if the right pads have been used, Cooper vs S. Did you compare new and old pads to check? If the dealer used your car's identity to decide on pad choice, this error shouldn't be possible and I don't know if it can be physically made - when converting my Yurpeen diesel from Cooper to S brakes, I didn't compare the pads.
I apologise if I sowed the seeds of doubt - it's just what came into my mind and out through my fingers without my brain filtering it.
I'm no expert on first generation cars but wasn't 2006 the changeover year from R53 to R56? Someone here should know.
But that does suggest it is possible to have pads meant for the wrong car. Looking at RealOEM, the brake pad part numbers would be:
R53: 34116770332
R56: 34116778320
I see the R56 pads was also used in R53s - that would be in the JCW brake option, I think.
R53: 34116770332
R56: 34116778320
Have you taken this complaint back to the dealer to have them cross reference and make sure they're the correct pad? Could very well be the wrong pads. Just for kicks, to add another idea to the pot, it sounds like it's possible that the pads are moving. Sometimes this is simply fixed by putting a type of adhesive tape (3M tape) on the back of the pads. I've seen this happen a few times on non-Mini cars. If you look under the brakes section of these tech articles here, take a look at them and make sure everything was installed properly. Good luck.
edit: to cross reference part numbers, I believe front pads OEM # is 34-11-6-770-332. Check out the parts catalog here for other part numbers if needed.
-Luccia
-Luccia
888.280.7799 | 6am - 5pm PST
GEN2 begins with 2007 model year for hard top
basic GEN1 pads differ greatly from GEN2 pads (and GEN1 JCW brakes are the basic GEN2 fronts for an S)
GEN1 fronts are the same for a non JCW S and a JUSTA
GEN1 fronts, the inner pad has a big 3 prong clip that fits INTO the caliper piston.
example from MINIMANIA
Worn out brake pads? These are Value Line replacement FRONT Brake Pad set for the BMW Mini Cooper and Cooper & S. Not for MINIs with the JCW Sport Brake option (with the red front calipers).
Item: Front Brake Pad Set
Fits:
2002-2006 R50 MINI Cooper and R53 Cooper S Hatchbacks
2005-2008 R52 MINI Cooper and Cooper S Convertibles
Front pads not compatible with JCW Sport Brakes.
GEN2 pads have no such clip and the tabs at the ends of the pads, where they fit into the grooves of the caliper are different . . .
if OP got the wrong pads I'd think he noticed . . .
did you do only the fronts? cuz this kind of issue is more common on GEN1 rears which also have a spring clip arrangement on the inner pad, and this one is easy to install wrong . . .
Fits:
I wish it was an incorrect part#. but I don't think that's the case.
Here's the part# I found on my receipt and on the box (34-11-2-167-233). when i look up my min's last 7digit vin online, i was able to pull up this part#. I will take the pads out tomorrow and re-inspect and go over my installation again. If the knock continuous, I'm taking the pads back to the dealer. wish me luck.
ok...so i took the front brakes apart, cleaned up eveything, re pasted the back of the pad and made sure the spring clamp holding the caliper assembly ok...also picked up some fresh rotors since im already taking everything apart..took the mini for a test drive and voila, the knock is gone. i was not able to identify what the exact problem was but what im guessing was maybe the pad have moved a little bit when i was using the old rotors and that what i think might caused the knock. after putting the new rotors in, there was not much space for the pads to move around. maybe someone else with more techy experience could of solved the issue without replacing the rotors...but anyways..
thanks for everyones help on this. im really happy the issue got resolved.
07-16-2020 01:54 PM
iamcamkeenan
08-10-2015 04:31 PM
