Newby Owner asking for a heads up...
Hey Gang,
Bought a used '08 Convertible S Monday w/ 71k.
What do I need to watch out for? What should I start saving my $$ to fix? What should I do today to make it still be a happy part of my life in 10 years?
Also, so I can get used to the terms, I own an R52, correct?
Thanks!![Thumbs Up](https://www.northamericanmotoring.com/forums/images/smilies/thumb-up.gif)
John
Thanks!
John
Congratulations - Welcome to the family! You have the last year of the R52, which in the S model has a supercharged engine. Many consider it to be more reliable than the turbocharged engine that came after it. The R50/52/53 cars are known to need front control arm bushings as they get older, so that's something for you to plan for.
Vendor
Yup you have an R52 Cabrio.
Control arm bushings are the most common item to wear out. With 71k you prob already need them if they weren't already done. Go with the powerflex control arm bushings as they will last forever.
The Harmonic Balancer is a big chunk of rubber and over time drys out and will just fall apart throwing the belt and leaving you stranded. We replace these with the ATI Damper as we do about one a week in our shop.
Thermostats are pretty common coolant leak.
Other than that other problems normally can be found with regular inspections when doing your maint.
Thanks all.
I have some of the maintenance records, but not all.
What are the symptoms I should be looking for as the control arm bushings wear?
Do I have anything to worry / plan for in the timing belt / chain department? I know as some vehicles age this becomes an expensive wear item.
Thanks again!
-JB
Thanks again!
-JB
Vendor
On an R52 timing chains are not a common failure. Normally if anything goes wrong with them the guides wear and give you a rattle noise which is normally a warning they need replaced. rarely if ever do the suddenly fail.
Welcome. I would check those LCAB first and then if they are bad, check all the rest off on the front suspension.
On the front end here are the items to check out and replace:
https://www.northamericanmotoring.co...ll-joints.html
![](http://c1552172.r72.cf0.rackcdn.com/225072_x600.jpg)
![](http://c1552172.r72.cf0.rackcdn.com/418269_x600.jpg)
On the LCAB recommend the PF as its a once and done thing.
The R52 is the Gen 1 MINI Convertible.
Other the that the biggest issues with the convertible is the sunroof function and those cable, by 2008 it had the most updated part, but I have seen then separate due t the seize and dirt the rail. Make sure the top works and grease all the moving parts, pivot points of that top .
Good section to learn about the convertible.
https://www.northamericanmotoring.co...mechanism.html
![](http://c1552172.r72.cf0.rackcdn.com/467034_x600.jpg)
When it comes to MINI Convertible ECS Tuning is your MINI part place .
![Smilie](https://www.northamericanmotoring.com/forums/images/smilies/smile.gif)
![](https://www.northamericanmotoring.com/forums/signaturepics/sigpic130940_6.gif)
-Luccia
888.280.7799 | 6am - 5pm PST
![](https://www.northamericanmotoring.com/forums/signaturepics/sigpic118226_4.gif)
Welcome, John! The best thing to do would be to bring it to a qualified MINI mechanic and have them go through it with a fine-toothed comb. You can then prioritize the repairs and maintenances based upon budget and goals.
![](https://scontent-iad3-1.xx.fbcdn.net/hphotos-xfa1/v/t1.0-9/11102741_1068832093130821_8702788705258422188_n.jpg?oh=cfe940779cf745e8fc15c3b55e30ec68&oe=55EE3756)
You are welcome. That stinks.
I hope you feel better soon.
Spank
11
04-09-2020 02:23 PM
eatsleepautox
10-30-2015 06:46 AM
