Hatch/Trunk alignment
Check the hinges, and make sure they are not loose or broken ( snaped ) . Also check to make sure those lower adjustable buffer are the same and one is not higher then the other at the bottom,.
Buffer
Diagram , look at # 2 and does it match in alignment to the other side.
http://www.realoem.com/bmw/enUS/show...diagId=41_1380
If broken or separated:
https://www.northamericanmotoring.co...nge-broke.html
Buffer
Are the hinges bolts mounted on the flat hole side are they about the same ? See pic above.
It might be something where you need to realign the rear hatch. The Bentley Manual here (MC-800-MC06) has a nice step by step process for the alignment on page 412-3. There are a few hatch adjustment points (each hinge, the buffer stops and the latch). Basically you loosen the hatch hinge bolts to allow movement and adjust accordingly. The manual provides gap specifications. Lastly, you can turn the buffer stops until they make contact with the hatch opening to complete it. The manual really has some great info in it so it does pay for itself.
-Luccia
-Luccia
888.280.7799 | 6am - 5pm PST
That may help , but if the hinges are bent or rusted at the hinge , it does not help you.
I can see they look to be in good shape. do they look bent on the hinge itself and on the mounts inside and under the rear of the roof.
Has the car been in a rear end collision or wreak ?
wildwestrider
11
01-29-2016 05:06 PM
daviday
09-25-2015 01:31 AM
