Rear Strut Mount Guide tube
So I purchased my R53 with a set of ST coilovers on it. It had a clunk in the back passenger side. I replaced the Sway Bar bushings and the Sway Bar end links. Clunk persisted. I then decided to replace the Upper Strut mount. ( I don't normally throw parts at a problem... but I figured its wise to replace these things anyway).
I ordered a Rear Strut Mount Kit from Pelican Parts, the Lemforder brand. When I removed the strut from my car and disassembled it, I saw that the Old bushings were the original Mini parts and Very very squished. There was no metal guide tube installed. Upon reassembly I noticed that the Guide Tube that came in the strut mounting kit did not fit. The inner diameter was too small to go on the strut. I assume this is why the previous owner decided to not install one when they put the coil overs in. But I have to assume this is causing the clunk from my rear wheel. I had no choice but reassemble the rear without the sleeve and the same clunk is present. Id really like to get that sleeve on there.
Is this a known issue with the ST coilovers? Did I get a bad sleeve with my kit? Looking for some insight.
This is the guide you're talking about correct?
Are you able to post a picture of the sleeve and the shaft of the ST coil. I'm not sure if the coil overs were supposed to come with something like that metal sleeve. It might be something where you need to call ST as it might be something missing from the coil over.
This is the kit correct? This is everything that should've come with it.
I'd like to know if someone else has this issue or what ST might say about it. I called them and they are wanting a photo of your set up. I would suggest calling their technical support at 1.559.875.0222. Believe it's option 4 and then just keep going through until you get an option for technical support. I assume just as you that the previous owner left it out because of the fitment issue. Please let me know what they say once you get them photos.
-Luccia
-Luccia
888.280.7799 | 6am - 5pm PST
Yes that is the same sleeve. And the one that came with it doesn't slide over the threads. I've since assembled the suspension and it's back on the car. I'll have to check that I still have the sleeve that came with it as I wasn't able to use it. I can try taking a picture. But not sure how that would add any clarity.
-Luccia
The lemfoder version fits a majority of the upper rear struts , For some aftermarket ones they way the lemfolder metal tube one is made , its so tight it might not fit over the rod, and its because of that C design. What people do is if they have an aftermarket strut that does not fit they can reuse the old center metal tube with the new Lemfoder two part form mount. The foam itself is the same diameter.
Or try to bend the C a hair larger, maybe a mm or two.
You can't get the tube by itself, but we do have the HT linked that has the MINI OEM design tube.
You can see both designs below.
If you have any other questions we are here to help.
http://www.ecstuning.com/Search/SiteSearch/33526754123/
33526754123
Fits most strut rods.
Metal solid tube design. Fits all.
33526754123
I can give them the part number off the strut if that will help to determine that I've got the proper suspension. But I don't really want to remove my coilovers to take a picture of a part that doesn't work. It sounds like the issue resides with the way the part is made by the manufacturer and it's incompatibility with the ST struts.
I don't have the original unfortunately as the previous owner didn't have it on there.
Perhaps my best bet is to just see if anyone is replacing their strut mounts and wants to donate their old used sleeve to me.
-Luccia
Sorry we cannot just get the sleeve for you , worst case you have to get the HT ones and then sell the foam part.
I would also try bending out that C tube a hair , but it might take smacking it with a tapered large punch inserted in the hole ( in a vice on one end ) on each end of the tube until it expands enough to go over the strut rod.
Good luck.
Good luck.
-Luccia
So my problem is now solved. I ended up purchasing a strut mount kit from RockAuto that included the correct tube. it was only $13. It was a Munroe brand and it fit perfectly. After installing, my rear clunk is now gone.
I'm glad this is now behind me. Although I have to be honest and say I'm a little disappointed that it wasn't mentioned on the online ad when I purchased the Strut mount kit that there might be fitment issues with anything but stock suspension. I have since gone back to check the listing and there is no mention of it by the retailer. There is however, a review of the product by someone who mentions a fitment issue. I'd have thought that there would have been further review to determine the issue the complainant was having. I hope this is the first and last issue with the retailer as Ive used they a few times now.
Thanks for the update. Knew it was the tube. We have the HT ones for around 12 , but glad you got it fixed.
JaysinStrife
Suspension
09-07-2015 12:52 PM
sabjcw
08-14-2015 07:40 AM
ClayTaylorNC
08-10-2015 09:19 PM
