Sheared bolt in wheel hub *HELP*
So My R53 has had some shudder under braking that was coming from what I believed to be warped rotors. Today I was taking off the rotors and calipers to replace then with new ones, and I discovered sheared bolts in the hubs. When I took off the caliper mounting bolts, the rotors almost fell off because the locator bolt was missing. Essentially the only thing holding the rotors on were the four wheel studs. I need help on what to do, should I try to drill out the studs? Or maybe replace them? Here is what it looks like;
Although nice to have, the rotor retaining bolt just helps hold it in place during assembly but once wheel is bolted up, the rotor is not going anywhere.
You replace the hub and u get a new wheel bearing. Looks like snow belt car. Use anti seize on the retaining bolt.
FYI some use anti seize on lugs. For the street it's ok yo use sparingly but check torque often.
For the track, NEVER EVER use anti seize on threads. They will not hold torque.
I discovered this at the track for myself.
SosoMINI
11-22-2015 03:17 PM
JPMontes3
08-23-2015 01:26 AM
Minibeagle
08-13-2015 10:00 AM
minipopkart
08-13-2015 05:22 AM
