Not starting.
Not starting.
This morning car cranks but doesn't start. Starter runs a few sec doesn't start. Repeat a few times. I open the hood. Check voltage (12v) screw around a little. Do nothing that should fix anything. Tried starting again in desperation and starts like nothing was wrong.
Battery is < 1 yr old
Starter didn't sound as expected. Just didn't sound like it was working hard but not free spin noise.
Does your MINI sit a lot? A typical reading would be in the 12.6-volt range when the battery is fully charged. If the reading is 12 volts or less, then the battery needs charging or needs to be replaced with a new one. Good DIY here with lots of information.
888.280.7799 | 6am - 5pm PST
![](https://www.northamericanmotoring.com/forums/signaturepics/sigpic118226_4.gif)
I'm sure you have, but just want to make sure everything is covered before suggesting to start replacing things. Make sure to check the ground strap and make sure that the terminals aren't loose. I would test the starter as well (not that this is your issue, but want to rule it out).
+1 for double checking the battery connections, I'd assume you disconnected the battery when you were working on the alternator. I had a similar problem with my car for a while, and it turned out that my negative battery terminal was vibrating loose just enough to not make good enough contact. It still looked fine, but I could push it down a little bit and the bolt was just a little loose. Do be careful with the bolts connecting to the battery terminals, I tried to tighten one too much and it snapped. I think it cost me like $10 at the dealer for a new one.
Thanks once more pelican
I didn't think of the ground straps. I did have the battery and the ground strap next to the upper engine mount off while replacing the alternator. Both seem on tight now but cleaning connections couldn't hurt.
Still a one off problem so hopefully just grounding.
papawhiskey
12-14-2015 01:10 PM
MC36
10-18-2015 01:12 PM
10-15-2015 11:12 AM
