Intake pipe between MAF and turbo broke
Your main concern should be the two sensors that are plastic welded to the intake. I'm not aware of an aftermarket setup that comes with those sensors. I had originally broke off those two sensors and secured them to my AEM intake using rtv. Now I have a new oem pipe with the sensors, mated with a modified AEM intake pipe.
dealer had one, price wasnt too outrageous.
thanks for the quick responses though wmw! I'll be placing an order for a few things in the next month or two (if this thing stays together) for some go fast parts.
Old inlet pipe was very brittle, slapped the new one on and no more turbo whoosh.
The pipe does come with the inner donut / seal on the end for the turbo:
#10 smooth type. Rubber Boot N18 Engine Cooper S . 13717627501
https://www.ecstuning.com/Search/SiteSearch/13717627501/
# 12 Hose Clamp ( rubber boot ( intake ) connection to turbo. Part # 13717577548
http://www.ecstuning.com/Search/SiteSearch/13717577548/ES35254/
Get a new clamp also , it has a special cutout on the clamp, the old ones can get beat up and the tube can work its way off the turbo, when you install the intake tube make sure the turbo connection is clean of oil.
OP has an N18, the N14 intake hose won't work.
It is a common failure like Way stated, we have started stocking the hoses due to the increase in failures we see.
If you're having issues with the tube slipping off the compressor housing we sell a flange that will keep the tube from coming back off in the future: Turbo Inlet Flange
01-14-2016 11:42 AM
12-30-2015 10:17 AM
Doc Pain
10-28-2015 07:30 PM
F55/F56 Replacing Bbs sr016 wheels
F55MidnightBlackCooperS
10-28-2015 07:50 AM
