What is this part????????
Old 11-20-2015 | 05:29 PM
Jim Ferrell's Avatar
Jim Ferrell
Had the winter tires put on today and the mechanic called me out to look at this. He said there was 1/4-1/2 inch play. What is this called and how hard is it to fix?? TIA!!!!!!!!!!!!!!
Old 11-20-2015 | 08:22 PM
Racingguy04's Avatar
Racingguy04
That's the infamous Lower Control Arm bushing (or LCA bushing) it's a bit of a bear to replace because almost everyone lowers/removes the sub frame to get at the other bolts that hold the bushing in place.
if you search the website you'll find tons of info on replacing these, and the general consensus is to replace them with powerflex bushings. You get better performance and longevity.
Old 11-20-2015 | 09:31 PM
Fly'n Brick's Avatar
Fly'n Brick
Hint: Click the down arrow on search and select 'Advanced Search'. It gives you more options and filters to refine your search.
Old 11-20-2015 | 09:51 PM
Jim Ferrell
Ok next question. Can they wait till spring or is this something I should get done right away?
Old 11-21-2015 | 12:23 AM
Racingguy04
I wouldn't say that it has to be done right away, but I don't think I'd wait til spring either.
The bushing being worn out will negatively affect your tire wear and it will also affect the handling. The bushings are around $100 and one member recently posted he was able to get his replaced for $400 so it won't break the bank.
Old 11-21-2015 | 01:03 AM
Jim Ferrell
Do you have a link to the power flex bushings? I can get those now then talk to the shop and see what they say about replacing them.
Old 11-21-2015 | 09:28 AM
Fly'n Brick
Click on the 'Marketplace' and visit the vendor pages. At the bottom of each vendor page is a selection for 'Specializing In', select suspension and it will narrow the vendor search. Several of the vendors carry Powerflex. You will be asked to enter the year and model of your MINI to be taken to the right 'shelf' in their shop.
Old 12-13-2015 | 01:11 AM
Minston's Avatar
Minston
Check this out, if you are ok with DIY these guys have some great articles: http://www.pelicanparts.com/techarti...eplacement.htm
I just had to replace mine and it is a lot of work but not that complicated, just taking off old and putting on new, pretty straightforward but it will take some time, I wouldn't make any plans that weekend, if you decide to DIY, Pelican also has the bushings. As long as you(or your mechanic)is doing this you might as well have your ball joints(inner and outer) checked as they are attached to the Lower Control Arm(LCA) and replacing them requires just a little extra time(and $ of course, Pelican has these too) at this point but if you have to do them later it will require doing basically the same amount of work as to replace the LCA bushings alone. Good luck and Motor On!!!
Old 12-14-2015 | 08:48 AM
Here is all the components of the front suspension, get the Powerflex LCAB versions and its a one and done thing. 31126757561 left & 31126757562 right , part # control arm bushing with mount.
https://www.northamericanmotoring.co...ll-joints.html
Old 12-14-2015 | 09:35 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
All the components are HERE. If any help is ever needed please just reach out to me and I will be glad to assist anyone.
888.280.7799 | 6am - 5pm PST
Ultraviolet1
12-07-2015 05:00 PM
pewx3
11-19-2015 10:31 PM
Murfman89
Tires, Wheels, & Brakes
11-18-2015 01:09 PM
PelicanParts.com
Car Care Products
11-16-2015 03:25 PM
PelicanParts.com
11-16-2015 03:25 PM
