Where is this coolant coming from
#52
THANKS.
#53
Hopefully, you didn't take "everything" apart again just to find the defect in that very easy-to-get-to hose section...
#54
Just put it into "service mode" and there's another short piece of hose to the lower radiator connection that's not OE too...... It seems to be a bit moist......
#55
#56
Two things, first there is a rubber o-ring inside the water pump, don't know how that could deteriorate but perhaps. Secondly, remember that is there is another o-ring where the water pump mates to the flange that bolts to the engine block. It is behind the pump, at a right angle to the pump impeller. The leak may be at the flange. You have to take the actual pump of as well. You can see the flange in your second picture, its is aluminum and the pump appears to be greasy/black. The O-ring is in side this aluminum flange.
Here is a link that has a video on how to get the pump off without removing the supercharger. Have you checked the t-stat housing as well?
https://www.northamericanmotoring.co...erheating.html
#57
Thanks, I probably should have mentioned that I replaced the water pump flange and O-rings on both the flange and pump when I did the supercharger oil service.
The thermostat housing and seal were both replaced a little while ago.
The only place I've found the coolant with die is, running down the front of the engine around the crank position sensor.......
I'm leaning towards replacing the water pump but I don't "think" it's very old......
Alpha Motoring
11-10-2015 08:08 AM
patsum
10-01-2015 07:33 AM
