Cylinders #2 & #3, zero compression; #1 & #4 at ~150
#26
#27
#28
Yea, was thinking kids also. But if no kids, then previous owner or something abuse.
#29
on
Nobody else in my household can drive a standard, so no teenagers or spouse.
<br />
#30
on
Ugh....
As I mentioned, I've been apprehensive to get on the car and really opened it up. That hasn't changed ... I've been pretty much driving like my grandfather, not wanting her to break again.
So yesterday, pretty much out of the blue, she starts doing an impression of a Ford 7.3L diesel:
Managed to get a hold of a trailer late yesterday, threw her on it and hauled her back up to the shop late last night and left her on their front doorstep with a note. Six hour round trip. This is becoming a battle of wills.
#31
#32
on
#33
When and if you do a rebuild , post up.
#34
on
Will do ... but not looking to do that anytime soon (I hope).
UPDATE: Shop said when they started the car in the morning it made the noise ever so briefly, then nothing ... just purred. They tried a number of more times, but no diesel impressions. Now I'm wondering if there isn't some residual material from the work the did on the head (valve replacement, cam replacement, port and polish) floating around that might be creating a clog that is/was preventing the lash adjusters from getting oil flow (as David suggests). They wanted to keep it overnight and drive it around to see if it would make the noise again. If that's the case (some debris), am I wrong in thinking that a good oil flush and change of a filter or two get whatever it is out?
#35
That will at least show whats floating around it any. like a oil test.
#36
on
UPDATE:
Okay, I guess the car finally made the diesel-like noise consistent enough so that the shop could diagnose the issue.
They say they are 100% confident that it is caused by weak lifters and recommend replacement of all 12 rockers arms. They posit that the work they did (valve replacement, cam replacement, port and polish) was just too much for the old lifters and that has brought them to this state.
This goes beyond my realm of knowledge. Idk, does this sounds plausible?
#37
As I mentioned, I've had lifter (valve lash adjusters) issues. Don't know what a "weak" one means, but do understand what one stuck closed means. Sadly, our lifters are integrated into the rocker arms. Instead of paying just for 16x$5 for the lifters, you have to buy new rockers - a whole set from AJUSA is about $350 from ECS Tuning or $700 from MINI.
I have cleaned them on other cars. Depending on your tolerance for pain. Brake cleaner or diesel fuel, followed by soaking/assembling in oil to remove residual solvent
#38
on
#39
#40
PM you gecko. David , spot on. Made is Spain I believe on these, come in nice oil filled containers. Supplier for OE.
#42
Welcome.
#43
LOL. I've got a secret technique.
I've been having some rocker noise after switching to 0W-40 oil and debating replacing one or more rocker arms again (I've since returned to 5W-30 oil).
Driving home last night I walloped the car on a big assed pothole. Thought I would bend a rim or get a flat. Nope. And my noise is gone !!!
#44
on
Strange coincidence ... same thing happened to me driving home the other week from the indy shop after having the valves/port/polish done ... except when I hit the front left sidewall blew out ... and guess who didn't have a spare with him at the time....?
Come to think of it, she developed the rocker noise after that. Damn, I need to find another big-*** pothole.... <br />
<br />
#45
Its like the "fonzie method" for gen1 door motors.
#46
#47
#48
on
And as for mine . . . happy to report that after the indy shop replaced all the rockers arms (went oem), she is purring like a kitten.
As part of the job, I also had them throw in a DT BPV I had picked up a little while back. I like how the BPV makes the car feel, but the day after I got her home she threw a P0171 code (system too lean). Cleared it, but because of snow, I really haven't driven the car since until today.
<br />
<br />
<br />
<br />
#50
The OE supplier is Stanadyne. They made the lash adjusters in the U.S. and the rocker arms in Brazil.
