Missing air dam part
OK, so I'm pretty sure a previous owner probably ran something over as I'm missing a lower plastic panel and that weird air dam that is mounted sort of behind the engine. Also there is a crack in the lower radiator plastic mount. Want to make sure I order the right thing, anyone have a part number for these pieces and which of our vendors here has them? Thanks in advance for any help.
Thats the stock part 51757201784 for the automatics MS 1/2005+ or the moded MINI upgrade
https://www.northamericanmotoring.co...-2005-r53.html
: 51757201784
https://www.ecstuning.com/Search/Sit...h/51757201784/
and
51757201453 Air Channel For Power Steering Fan
https://www.ecstuning.com/Search/Sit...h/51757201453/
If you are looking for the stock one and dont have an auto 1/2005+ or modded.
Then: 51757201782
https://www.ecstuning.com/Search/Sit...h/51757201782/
The above's come with the speed screws and everything.
Or You can get the Rennline version * For vehicles with manual transmissions . has a access point for oil changes.
U01
https://www.ecstuning.com/Search/SiteSearch/ES2840601/
: 51757201784
and
Then: 51757201782
U01
F55/F56 Missing floor jack in trunk
Albert Godoy
01-05-2016 08:34 AM
PeppersprayMCS
18
12-28-2015 02:58 PM
