R53 Mini S Voltage
R53 Mini S Voltage
I've searched, found promising statements and a bunch of conflicting statements.
What should the voltage read at idle no lights/ac/stereo? I'm seeing 13.3v-13.6v
What should the voltage read idle with load such as ac/stereo/lights? I'm seeing 12.2v-12.6v
after driving a length of time 5-15min, then sitting idle I'm seeing voltage 11v-11.8v with load sometimes dipping in the high 10's.
after driving a length of time 5-15min, then sitting idle for 5-10minutes I'm seeing 12.2v
While driving stopping and turning with the fan on 2 and ac on I'm seeing voltage always dipping to 11.8-12.1v
After driving for about 5-10 minutes I'm seeing the EP light on gear selector (stronic), Tire pressure, check engine and we are seeing the following codes.
p1747
p0700
p1613
p1611
Switched out TCM and had the battery checked.
p1747
p0700
p1613
p1611
12.9 is the break even point. Below that you are not charging, but discharging. Normal loads from light and such should not affect the charge voltage at all.
This assumes you are measuring the actual battery terminal voltage. If you are looking at the volts reported by the ecu that might be different.
I know this is like 2 years late. I've been holding on to this car because it bothered really bad that it broke so sudden.
I fixed all these codes
p1747
p0700
p1613
p1611
By replacing the Tachometer above the steering column.
I noticed this thing started acting up (going off/on) a few months later. It made me wonder if this was the root cause and was just not showing symptoms at first.
I replaced this with one off ebay for $25 bucks a few weeks back. So far she is still up and running.
No more codes, no more EP, no more transmission not shifting.
p1747
p0700
p1613
p1611
a4dude
01-28-2016 12:38 PM
Semaphore
01-26-2016 07:58 AM
tlmease
01-20-2016 02:58 PM
