Driver side door stuck?
Old 03-07-2016 | 11:59 PM
MINISPNKY's Avatar
MINISPNKY
Hey guys,
Have a bit of a problem with my driver side door and was wondering if anyone has fixed/found a solution for this. I have tried opening the door skin and played around with the cables, but I could not find the issue.
My door will not open and the lock mechanism looks to be stuck. When I press the unlock button I can hear the lock motor try rapidly unlocking it 3 times and fail. Pulling on the handle inside and out will not work.
Any input is appreciated! All I need is a solution to open the driver side door so I can tear everything apart.
P.S. passenger side door became unresponsive also but the lock mechanism works still (lock pin goes up and down).
P.S. #2, this issue is not weather related as I have had this problem since summer.. just sick of crawling through the passenger side!
Thank you!
Old 03-08-2016 | 07:35 AM
Its the actuator most of the time. One side goes then the other side goes. They get weak , then fail.
https://www.northamericanmotoring.co...-problems.html
Old 03-08-2016 | 09:19 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
You'll definitely want to try and get into the panel to see if it's the bowden cable that is the issue (probably isn't because you'd most likely be able to open from the outside) or if something is not attached or the actuator isn't working properly. Some advice on post #13 for removing it while the door is closed. https://www.northamericanmotoring.co...ml#post3049828
888.280.7799 | 6am - 5pm PST
daveke
05-19-2016 02:29 PM
Dan Wink
R59 :: Roadster Talk (2012+)
02-10-2016 07:35 AM
Pertplus
02-10-2016 05:14 AM
tpetro33
02-09-2016 06:05 AM
Nick Royer
02-07-2016 11:35 AM
