Help with Washer Fluid Hose Replacement
Last night when I was re-filling my washer fluid reservoir thinking the reason I wasn't getting any fluid was because it was empty, I noticed that the washer fluid tubing/hose on my 2013 Hardtop S had broken in half. There's a clear break about halfway between the jets and the reservoir.
I found the replacement hosing online but I was wondering if anyone had a DIY on how to replace it. The rear jets to the back windshield are not affected so it's just the front windshield. Does anyone have a how to for this? I'd really like to avoid the dealership since it seems something that should be pretty simple to do.
Let me know if you guys know how to do this.
Thanks,
Thanks,
Right here: 61667220827
https://www.northamericanmotoring.co...ose-broke.html
Diagrams is linked it just unclips and a new one in , press the hose into the nipples on the washer jets and the end hose goes down by the pump. Might have to go through the front left wheel well to hook it.
http://www.realoem.com/bmw/enUS/show...diagId=61_2184
Got our site here http://www.pelicanparts.com/catalog/...17_catalog.htm and click on the "tech info" tab at the top. Scroll down and it's by the bottom under "Body."
888.280.7799 | 6am - 5pm PST
http://www.realoem.com/bmw/enUS/show...diagId=51_6296
get some of these , they always break when i pop the out, use a fork split flat head tool to hold the base of them from spinning and the Philips screwdriver to unscrew. 07130702966
https://www.ecstuning.com/Search/SiteSearch/07130702966/
Headlight washers: https://www.realoem.com/bmw/enUS/showparts?id=MF73-USA-09-2008-R56-Mini-Cooper_S&diagId=61_2185
windshield washers: https://www.realoem.com/bmw/enUS/showparts?id=MF73-USA-09-2008-R56-Mini-Cooper_S&diagId=61_2183
Resivor: https://www.realoem.com/bmw/enUS/showparts?id=MF73-USA-09-2008-R56-Mini-Cooper_S&diagId=61_2184
Rear https://www.realoem.com/bmw/enUS/sho...diagId=61_2181
Can you post up some pics?
