2008 Mini Cooper smell when AC cooling
I recently bought a Mini during the winter months and didn't try out the AC cooling when buying; only tried the heating which works fine. Today it was warmer and it got hot inside the car so I turned on the cooling and immediately there was a horrible smell, a bit reminiscent of vomit. Very unpleasant. The smell did not appear to get any better over time so I switched off the cooling. Then there was no more smell. What could be causing this and how to fix it?a
I'd check the cabin air filter area well and also make sure there isn't a dead animal in the system anywhere. When I worked at the dealer we pulled a lot of big rats out of the cabin air filter areas/vents. Check the vents, etc. It can happen. Could also be mildew, etc. Some more info HERE.
888.280.7799 | 6am - 5pm PST
Open the hood take off the shroud covering the battery, check for anything in this area as this is where your fresh air comes from. Leaves, water mold, bugs rodents...Sad but true, fresh air from around the battery!
If you put your AC in fresh mode, you will actually see the top of the cabin air filter. In recirculation mode, the door closes over the filter.
MarcSellsMiami
03-31-2016 09:16 PM
