Water pump needs replacement?
Hello,
I had recently noticed that my '10 MINI Clubman S (39K on the clock) was a tad low on coolant so I filled the overflow to the required level. I left it in the garage for about a week while we were out of town and when I pulled it out of the garage, I noticed a small pool of fluid that looked like it came from close to the front passenger tire.
I jacked it up and had a peek at the front of the block and there was a green drop of liquid hanging on a pulley near where the water pump is located. I was running short of time, so I put the car back on with the intention of researching this further.
I've watched a few DIY's on replacing the pump and it does seem to be a slight nuisance to access. Local MINI service department wants $780 to swap it out and a local indy quoted $585. Parts would cost approximately $200, but I read that it could take a few hours to the better part of a day to complete.
I have the Bentley manual and I don't recall it saying anything about removing motor mounts etc. to jack up the engine. But looking online, it seems that all the DIY's mention doing this. What is the best way to do it if I do decide to tackle it myself?
Before tearing into my baby, I would want to have definitive knowledge that the pump is going. Are there any other tests that I would need to do to find this out? Anything I should look for?
Thanks.
Thanks.
Clean area and recheck Also maybe rent or borrow a pressure tester and look for the dribble
Pelican parts has a good DIY here. http://www.pelicanparts.com/techarti...eplacement.htm.
Lots of vendors have the parts. You may want to do preventative repairs while in there
There a great DIY here and I explain what to look for and tip when i did all my coolant at once,
Parts linked here
https://www.northamericanmotoring.co...8-no-heat.html
As if you have an issuse since i do the work myself I am here to help
Parts linked here
After reading through the DIY's on the ECS site, watching a few youtube videos on replacing the pump, I think I'm more comfortable with doing this myself. Thanks ECS for posting the links.
To get a better idea of what I am facing, I jacked the car up again and crawled back under to have a second look. I looked to see if there were any other areas that were leaking and all that I found was the weep hole on the pump dripping coolant. Once it starts leaking out the weep hole, generally how long do I have before the pump totally craps out?
What other sort of preventative maintenance should I do when I'm in the area?
Thanks for your help.
You are welcome.
Not long, mine did it at the bottom. You don't want to overheats.
While there check the thermostat, make sure you had the Aux water pump recall done, check the expansion tank and waterpipe/ thermostat.
I did mine all at once.
davidbeaver1
02-22-2016 07:07 PM
