Leaking coolant temp sensor O-ring replacement?
Old 04-05-2016 | 08:18 AM
fixthedoor's Avatar
fixthedoor
So this weekend I performed an oil change and changed my valve cover gasket, when I noticed a leak in the coolant system. It's a recent development as I did not notice it when I changed the oil about 8k miles ago. I have not been able to locate a part number online for the sensor, can someone point me in the right direction?
I could probably just replace the O-ring, but I'd like to see what the sensor costs. While searching, I found a very similar part for a BMW ($20), but unfortunately I didn't record any info off the sensor from my car when I had it out.
Here are a couple pics:
Old 04-05-2016 | 10:18 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Have you replaced the thermostat yet? The new thermostat design has the temp sensor in the thermostat (look at yours it's under where the bleed screw is). Image of it HERE. Therefore, it renders that sensor location useless. Do you have an automatic or manual? The new elbow piece that eliminates that sensor location for an automatic is HERE and manual is HERE. If you don't want to buy the hoses, and have the updated thermostat with sensor, people have installed the old sensor with RTV to help seal it permanently. If you don't, you may try your luck at an auto parts store and see if you can find the right size o-ring replacement until it comes time to replace your thermostat.
888.280.7799 | 6am - 5pm PST
Old 04-13-2019 | 02:18 PM
serenale's Avatar
serenale
[Hello, I have the same problem. Is your problem solved? Is this sensor removed from your car? I found Manufacturer Part Number is 13 62 1 433 077 Thank you .
Attachment 143992
Attachment 143993
Old 04-15-2019 | 09:00 AM
Yep this is the part and you can get the o-ring. Make sure its seated correctly and the tap did not break on the old part, we have seen that happen which require a whole new part.
https://www.ecstuning.com/Search/Sit...h/13621433077/
davidan
05-02-2016 12:35 AM
Martys
03-04-2016 06:49 AM
user 9388
02-28-2016 09:13 PM
E-dot
02-24-2016 09:29 AM
stevepsd
02-17-2016 01:29 PM
